While looking at pages of Lucas humor I stumbled upon this list of color coding for wires and thought it might be useful to some.
From: ( http://www.peterrenn.clara.net/archive4.html )
So there you are, grubby Haynes Manual in one hand, circuit tester in the other trying to work out why the lights/horn/wipers/cigarette lighter/clock etc. won't work, (apart from the fact that it has 'Lucas' stamped on it that is.) Tracing the circuit usually works eventually but often you find yourself with several loose wires and no clues as to where they go, in which case you need a clue or two.
There is a British Standard for vehicle wiring (who said "abysmally low"?) number BS-AU7a which defines the colours and allows you to trace where the wires should go from first principles rather than a diagram. It also allows accessories such as electric fans to be added with the correct coloured wires which assists later diagnosis enormously.
None of this helps the fact that the things on the ends of the wires are usually made by Lucas too and are therefore of er.. variable quality! I'm particularly fond of a description of an E-type Jaguar's headlamp switch as having" three positions: DIM, FLICKER and OFF.
Anyway, that's enough potentially libellous comments (I'm sure all Lucas products are simply fab nowadays and the repro stuff is only crap because it is so authentic
This info should not only allow you to trace original wires but also to use the correct colours when adding additional equipment like spotlights, ejector seats or whatever.
Firstly the basics- What The Colours Mean:
BROWN is for direct, unswitched, unfused supply from the battery. Seen on wires to alternators, dynamos, control boxes and ignition switches etc. Always live and often carrying heavy current.
YELLOW sometimes used as an alternative to brown on older cars. Also used on solenoids and overdrive switches.
PURPLE Direct, unswitched but fused supply from the battery. On older cars with no purple wires, brown wires with a secondary tracer colour are used.
WHITE Unfused supply from the ignition switch.
GREEN Fused supply switched via the ignition switch. Used for things like the wiper motor, indicators and brake lights which only work when the ignition is on.
BLUE The main colour for front lights- headlamps and spotlamps.
RED The main colour for rear and side lights.
BLACK Usual colour for wires from components to earth points on the body.
These refer to the main colour of the wire. The second tracer colour which is on many wires is the thinner line and is used to identify the wire. There is a certain amount of logic to them too as you will see.
Below is the colour code table for BS-AU7a which was amended in the 'eighties so there will be a few variations on our '50s to '70s cars..
Main colour is given first , tracer second
MAINLY BLACK WIRES
Black All earth connections
Black/ Brown Tachometer generator to tachometer
Black/ Blue Tachometer generator to tachometer
Black/ Red Electric or electronic speedometer to sensor
Black/ Purple Temperature switch to warning light
Black/ Green Relay to radiator fan motor
Black/ Light Green Vacuum brake switch or brake differential pressure valve to warning light and/or buzzer
Black/ White Brake fluid level warning light to switch and handbrake switch, or radio to speakers
Black/ Yellow Electric speedometer
Black/ Orange Radiator fan motor to thermal switch
MAINLY BLUE WIRES
Blue Lighting switch (head) to dip switch
Blue/ Brown Headlamp relay to headlamp fuse
Blue/ Red Dip switch to headlamp dip beam fuse. Fuse to right-hand dip headlamp
Blue/ Light green Headlamp wiper motor to headlamp wash pump motor
Blue/ White a) Dip switch to headlamp main beam fuse
b) Headlamp flasher to main beam fuse
c) Dip switch main beam warning light
d) Dip switch to long-range driving light switch
Blue/ Yellow Long-range driving light switch to lamp
Blue/ Black Fuse to right-hand main headlamp
Blue/ Pink Fuse to left-hand dip headlamp
Blue/ Slate Headlamp main beam fuse to left-hand headlamp or inboard headlamps when independently fused
Blue/ Orange Fuse to right-hand dip headlamp
MAINLY BROWN WIRES
Brown Main battery lead
Brown/ Blue Control box (compensated voltage control only) to ignition switch and lighting switch (feed)
Brown/ Red Compression ignition starting aid to switch. Main battery feed to double pole ignition switch
Brown/ Purple Alternator regulator feed
Brown/ Green Dynamo 'F' to control box 'F' Alternator field 'F' to control box 'F'
Brown/ White Ammeter to control box. Ammeter to main alternator terminal
Brown/ Yellow Alternator to 'no charge' warning light
Brown/ Black Alternator battery sensing lead
Brown/ Slate Starter relay contact to starter solenoid
Brown/ Orange Fuel shut-off (diesel stop)
MAINLY GREEN WIRES
Green Accessories fused via ignition switch
Green/Brown Switch to reverse lamp
Green/ Blue Water temperature gauge to temperature unit
Green/ Red Direction indicator switch to left-hand flasher lamps
Green/ Purple Stop lamp switch to stop lamps, or stop lamp switch to lamp failure unit
Green/ Light green Hazard flasher unit to hazard pilot lamp or lamp failure unit to stop lamp bulbs
Green/ White Direction indicator switch to right hand flasher lamps
Green/ Yellow Heater motor to switch single speed (or to 'slow' on two- or three-speed motor)
Green/ Black Fuel gauge to fuel tank unit or changeover switch or voltage stabilizer to tank units
Green/ Pink Fuse to flasher unit
Green/ Slate a) Heater motor to switch ('fast' on two- or three-speed motor)
b) Coolant level unit to warning light
Green/ Orange Low fuel level switch to warning light
Light green Instrument voltage stabilizer to instruments
Light green/ Brown Flasher switch to flasher unit
Light green/ Blue a) Flasher switch to left-hand flasher warning light
b) Coolant level sensor to control unit
c) Test switch to coolant level control unit
Light green/ Red Fuel tank changeover switch to right-hand tank unit or
entry and exit door closed switch to door actuator
Light green/ Purple Flasher unit to flasher warning light
Light green/ Green Start inhibitor relay to change speed switch; or switch
to heater blower motor second speed on three-speed unit
Light green/ White Low air pressure switch to buzzer and warning light
Flasher switch to right-hand warning light; or
Light green/ Yellow differential lock switch to differential lock warning light
Light green /Black Front screen jet switch to screen jet motor
Light green /Slate Fuel tank changeover switch to left-hand tank unit; or entry and exit door open switch to door actuator
Light green/ Orange Rear window wash switch to wash pump; or cab lock-down switch to warning light
MAINLY ORANGE WIRES
Orange Wiper circuits fused via ignition switch
Orange/ Blue Switch to front screen wiper motor first speed timer or intermittent unit
Orange/ Green Switch to front screen wiper motor second speed
Orange/ Black Switch to front screen wiper motor parking circuit, timer or intermittent unit
Orange/ Purple Timer or intermittent unit to motor parking circuit
Orange/ White Timer or intermittent unit to motor parking circuit
Orange/ Yellow Switch to headlamp or rear window wiper motor feed, timer or relay coil
Orange/Light green Switch to headlamp or rear window wiper motor parking circuit timer or relay coil
Orange/ Pink Timer or relay to headlamp or rear window wiper motor feed
Orange/ Slate Timer or relay to headlamp or rear window wiper motor parking circuit
MAINLY PURPLE WIRES
Purple Accessories fed direct from battery via fuse
Purple/ Brown Horn fuse to horn relay when horn is fused separately
Purple/ Blue Fuse to heated rear window relay or switch and warning light
Purple/ Red Switches to map light, under bonnet light, glove box light and boot lamp when fed direct from battery fuse
Purple/ Green Fuse to hazard flasher
Purple/ Light green Fuse to relay for screen demist
Purple/ White Interior lights to switch (subsidiary circuit door safety lights to switch)
Purple/ Yellow Horn to horn relay
Purple/ Black Horn to horn relay to horn push
Purple/ Pink Rear heated window to switch or relay
Purple/ Slate Aerial lift motor to switch up
Purple/ Orange Aerial lift motor to switch down
This info should not only allow you to trace original wires but also to use the correct colours when adding additional equipment like spotlights, ejector seats or whatever.Firstly the basics- What The Colours Mean:
MAINLY BLACK WIRES
MAINLY BLUE WIRES
MAINLY BROWN WIRES
MAINLY GREEN WIRES
MAINLY ORANGE WIRES
MAINLY PURPLE WIRES
