The green bible says that the 3.5 litre V8 should have a minimum compression test of 135psi. I measured mine today and got readings of about 100psi (wet and dry). They were pretty balanced all the way around.
This does not sound that bad. What do you think?
I get a little blue smoke from the tail pipe and I am not sure if it is rings or valve seals or just what....
