Thinking of a suspension upgrade. 95% road driving but aggressive driving where response is appreciated!. With 90K, noticed the suspension is getting a bit plush. So the question is are some basic things to do to improve my suspension response? Should the springs be addressed. No sag really noticed so do I move on to the shocks? Looking at the new OME which discuss heavy loads, oversized tires which tell me they may be a bit stiffer. Bilstein shocks describe normal loads/tires, impression - standard replacement. So if greater response is desired, then the OME's. Any thoughts to this?
Also was looking at a 2" spring lift. (the spacers to add under the spring base plate). Would this affect other things along the drive train? ie. rotoflex drive shaft flanges etc, and would brake lines need to be extended for only 2"?
