I just imported a "1980 110" from the UK BUT the 110 was not produced until 1983 or 84. The transmission looks modern day. There are no leaf springs and modern day dash and steering wheel. Disc brakes in front. The engine is a 4c petrol. The serial number is on a replacement tag and is shorter then most. Broken down it indicates the 110 is a 6C, built before 1980. It is obvious this was a theft recovery at one time. It had a valid UK V5 and MOTs. It was first registered in the UK in 1991 which is typical of ex-govt vehicles. Any ideas on how I can tell what year it is? It could be a 1991
What year is my 110?
sigpic
Nate B
88 D90 RHD, V8 Present
80 Merc 230GE Petrol in 2011
92 Range Rover - In the 90's
cuis2000@yahoo.comTags: None -
Do you have some pix?
On the screen glass is it Triple X or Securif as manufacturer?Les Parker
I will check this evening.sigpic
Nate B
cuis2000@yahoo.comComment
All glass has triple xxxsigpic
Nate B
I am using an iPad. Let me have an email address and I can send some picssigpic
Nate B
Presuming it's the original chassis, what's the chassis s/n# ?
Chassis Numbers (from lrfaq.org):
90, 110, 130 & Defenders:
- Found in the behind Rover's left front corner of the windshield
- Stamped on plate Riveted to the top of the brake pedal box in the engine compartment
- Stamped on the right-hand side of the chassis forward the spring mounting turret
Figured it out from the glass. 2Q, 1984
Thanks RNsigpic
Nate B
