What type of mileage can you expect out of the TD5? 300,000? 400,000?
Anyone here with Defender 130 driving experience/owner
They aren't known for longevity,especially if you coax more power out of them. Read up on them on a couple of the UK forums
and the fellows in Oz
DividingCreekImports.com
Tdi 130 Crew Cab x2
110 V8 5 doorComment
i drive a 130 TD5
its my daily driver and so far i LOVE it........
my only issue so far was really the starter.....replaced it once with a refurbished starter that lasted about a month....now i got a new one in and so far so good.
if your in a cold climate my only other creature comfort issue would be the heat........there is no heat unless you are driving at highway speeds....then heat is great.......once i slow down the air cools right off......
my truck is just over 180,000 Km.........Comment
I have owned my RHD 130 crew cab for about 10 years now and for the last 8 years it was my daily driver here in Los Angeles. It's a 3.5 litre V8 with LT85. I love driving and the only complaint I have is that in the summer it can get pretty hot without AC. I sound deadened it soon after I bought it and it help a lot with engine and road noise. The window mechanisms were shot so I rplaced them with a power window kit off Ebay for $90, it was an cheap easy solution to and expensive problem. All in all I still love driving it but now it seems to only get driven on long vacations, I need to start paying more attention to her.Comment
my first starter just stopped working.....one minute it was fine and then just click click click but that was it..........long story short i bought a reconditioned one and had a sorta friend sorta mechanic replace it for me........turned out to not be such a good idea.
It wasn't installed properly and the top bolt was stripped out.......when i turned the key over the teeth were not making good contact.....worked ok for a week and then started getting harder and harder to start till it just wouldn't start at all anymore.........when we pulled the starter out it had 3 teeth left on it. anyway. new starter and its been perfect since.Comment
i drive a 130 TD5
my truck is just over 180,000 Km.........DividingCreekImports.com
Tdi 130 Crew Cab x2
hmmm yeah im starting to get the feeling something is up.......everyone keeps saying it shouldnt be the way it is.
its super hot and great when im driving along on a highway but as soon as i get off the highway within 2 minutes air is cold again........im gonna look into it a bit......
on another note, you have a 130 coming up for sale soon?
im interested.......Comment
Kolton...you selling yours already?? Or just adding a 2nd to the stable?Comment
so i cant belive im even going to tell you guys this but i checked my coolant level today and it was EMPTY!! im talking EMPTY......truck never showed any signs OTHER THEN NO HEAT!
I filled it up today and PRESTO I HAVE HEAT!!! ive been driving around freezing for the last month and all i needed to do was add some coolant.......
SO now i love the 130 even more!!!Comment
Just the reservoir was empty? Or the radiator? In assuming the former....but keep an eye out for where you may have a coolant leak as its a closed system and shouldn't disappear.
Had you checked it since you bought the vehicle?Comment
I never checked it since i bought it......drove it on some pretty hot days and the temp guage never went above normal.......
I will definitely keep an eye on it but i have not seen any leaks...and no signs of leaks....other then there not being any coolant anyway......
we shall see!Comment
Kolton,
I know you sold the truck but Td5's have a myriad of places where coolant can leak like the O rings on the fuel cooler etc.DividingCreekImports.com
Tdi 130 Crew Cab x2
