I am wanting to renew my gasket and have removed all the bolts but cannot free the pan from the engine block.  I have tried to pry with a flat head and bang with a rubber hammer a bit.  Any suggestions?  The manual just says "remove it"   Thanks !
					Freeing up oil/sump pan
 Freeing up oil/sump pansigpic
 Nate B
 88 D90 RHD, V8 Present
 80 Merc 230GE Petrol in 2011
 92 Range Rover - In the 90's
 cuis2000@yahoo.comTags: None
 Are you sure you have all the bolts out? Take a flashlight and carefully follow the perimeter of the oil pan, there are a couple between the back of the oil pan and the bellhousing that frequently get overlooked (don't ask how I know). If they're all out, the PO may have used a very strong sealant but I've never seen them stick so tight that a rap with a dead blow hammer won't loosen them.Gale Breitkreutz
 '03 Disco
 '47 CJ2A
 yep all the bolts are out, I am just a little weary of using too much force and there is not a lot of swing room. I took a 2x4 and rested it on the oil plug housing and gave it a couple good wacks. The wood fractured where it met the housing. Just got love these things !sigpic
 Nate B
 cuis2000@yahoo.comComment
 Hope not, the "seal" leaks oil.sigpic
 Nate B
