oil recommendations
  • l.a. rover
    • Jul 2010
    • 108
    oil recommendations
    greeting fellow rover enthusisist! i just recently purchased a defender 110 with a 2.5 diesel n/a..... does anyone know what kind of motor oil it takes??? what about the tranny and diffs?
    thanks you very much!
  • Les Parker
    • May 2006
    • 2020
    In the LT 77 or R 380 Gearbox use MTF, axles/Transfer box : 75/90w Hypoid oil, engine/filter 15-40 (we use Amsoil on all of these )
    • l.a. rover
      • Jul 2010
      • 108
      Les.... Thank you! Also.... WHat is "MTF"?
      • RoverDover
        • Jan 2010
        • 144
        Dexron. Automatic Transmission Fluid.
        67 angry hamsters
        • antichrist
          • Mar 2009
          • 272
          MTF=Manual Transmission Fluid.
          It's not the same as Dexron ATF.
          I use Redline MTL in the gearbox.
          For motor oil I used Drydene Dieseall for many years, now owned by Castrol.
          Shell Rotella T would be good.
          Tom Rowe
          62 88 reg
          67 NADA x2
          95 D1 - R380
          95 D90 - R380
          97 D1 - ZF
          • l.a. rover
            • Jul 2010
            • 108
            thanks tom! I guess i didn't understand MTF cause my mind was thinking series rovers... hence 80-90w gear oil....
            • l.a. rover
              • Jul 2010
              • 108
              one more thng .... does anyone know what the oil capacity of the 2.5 na diesel????
              • RoverDover
                • Jan 2010
                • 144
                5 litres is just about perfect on mine.
                67 angry hamsters
                • antichrist
                  • Mar 2009
                  • 272
                  The manual states 7.23 US quarts with a filter change.
                  It will vary by about a pint depending on if you're using long or short filter.
                  Tom Rowe
                  62 88 reg
                  67 NADA x2
                  95 D1 - R380
                  95 D90 - R380
                  97 D1 - ZF
                  • l.a. rover
                    • Jul 2010
                    • 108
                    thanks.... cause 5 qts wasn't cutting it !
