I just did the timing belt on my 90 and to my great dismay the big bolt on the front of the crank was not sufficiently tight. ( it came off with short breaker bar and no effort at all) the last person to tighten this did not tighten it sufficiently or loctite it. As a result, the woodruff keys were damaged and my truck has had less than ideal pump timing for a while. luckily there was no damage to the pulleys or crank, but things could have been much worse. I hope this warning will incite you to check the torque on this bolt and I will be very happy if it saves much trouble and expense to at least one other person.
Warning to all diesel Defender owners!
Thanks!I just did the timing belt on my 90 and to my great dismay the big bolt on the front of the crank was not sufficiently tight. ( it came off with short breaker bar and no effort at all) the last person to tighten this did not tighten it sufficiently or loctite it. As a result, the woodruff keys were damaged and my truck has had less than ideal pump timing for a while. luckily there was no damage to the pulleys or crank, but things could have been much worse. I hope this warning will incite you to check the torque on this bolt and I will be very happy if it saves much trouble and expense to at least one other person.
jeff
67 angry hamsters
