Need advice on purchasing D110
 make sure there is no RUST on the rear crossmember, bulkhead kick panel/foot wells and door bottoms. Make sure that the tranny shifts properly... make sure the transition between first and second gear is smooth. if you have trouble shifting than your synchro might be worn out and need refreshening! make sure all indicator lights work and all other electricals.... good luck!
