Door Hinge Refurb
  • rbbailey
    • Sep 2010
    • 161
    Door Hinge Refurb
    OK, so I have some basically new, old style, SIII/Defender door hinges that I'm wanting to disassemble and paint and install on my IIa.
    CAN they be taken apart?
    Pointers on pulling the pin?
    What pointers should I know?
  • RoverDover
    • Jan 2010
    • 144
    A big frickin hammer and a darned good vise (and probably a few bent punches)! The holes are riveted after the pins are pressed in. I dont know where you would get new pins though. you would have to substitute something. Have fun and watch your thumbs!
    67 angry hamsters
    • Les Parker
      • May 2006
      • 2020
      Why refurb? The metal on the hinges is probably worn, new style Defender hinges are so much better and when all is is adjusted correctly, the doors close and hold like they should.
      Les Parker
      • ShootingCar
        • Jan 2008
        • 60
        How hard is it to remove the old hinges to install the new ones ?
        Jeff Pearl
        1969 SIIa 88 ECR Coil Spring Conversion
        North Central AZ
