The wildshield wipers are on continuously and will not shut off. The switch does activate the high setting, but you can not turn them off and the intermitent does not work either. I pulled the fuse for the windshield wipers which disabled the tachometer and the check engine light came on. When the fuse is replaced, the wipers are on continuously, the tac works, but the check engine light does not go out. Any suggestions?
Keeper135
Keeper135
