I'm curious to learn what is the 1st gear ratio in low range on a 1997 Defender with the factory equiped ZF automatic transmission? What is it in high range? If you know all four gears' ratios clue me in. What is the ratio on the differntials? Thanks.
'97 Defender gear ratios?
diffs are 3.54 www.expeditionlandrover.info has all the ratios you want to see.The Goat, 2.8 Daihatsu Td, '73 coil conversion
