MTF
  • Les Parker
    • May 2006
    • 2020
    MTF
    Changed the transmission oil in the DEf 90 recently to Amsoil MTF.
    What a difference !! Selects very well and NO notches on 2nd gear, as before with ATF.
    Les Parker
  • Jorge
    • 3
    Is ATF for auto transmission only or can I use MTF on my 97 D90, is your D90 automatic or stick ?
    • Les Parker
      • May 2006
      • 2020
      Jorge,
      My 90 is 5 speed manual, MTF is for Manual trans. ATF is for automatics.
      Up to now I have used ATF on my 5 speeds also. Now, it is time to rethink this strategy.
      Les Parker
      • spacemutt
        • Nov 2008
        • 142
        LT77 manual gearboxes should have ATF Dexron II oil.
        • Terrys
          • May 2007
          • 1382
          Land Rover always specified using ATF in the LT77 and R380 5 speed manual gearboxes, as well as always using it in all the auto boxes. Amsoil is one a few that have recently formulated a gearbox oil specifically for manual transmissions, and the point Les is making is that using it improved his shifting. Land Rover hasn't come out with any directive telling owners of LT77 and R380 gearboxes to use an MTF formulation as yet.
          My only concern would be the internal oil pump on these two gearboxes. Unlike most conventional manual gearboxes that get lubed by splash, the two Land Rover boxes have a forced oil circulation by way of an internal oil pump.
          • CliftonRover
            • Mar 2007
            • 351
            what oil should I run in my Lt95?
            • rwollschlager
              • Sep 2007
              • 583
              i too am interested in the oil for an lt95?
              I currently have 90wt in there and there does not seem to be any problems. Of course that could change if ive got the wrong stuff...
              72 SIII 88
              67 SIIA 109
              82 SIII Stage 1 V8
              • Les Parker
                • May 2006
                • 2020
                Landrover (NA), published a tech buletin ( Buletin # 007, CDS Ref L8462bu Dated 29-03-2000) detailing post WA> VINs all Range Rover, Discovery (1 and II) and Defender manual gearboxes were fitted with Texaco MTF from the assembly line.
                This also details that it would benefit earlier manual transmissions, if applyed on a full trans. oil change.
                My R380 dates from 97 and is appreciably easier on shift changes, just thought others might benefit from my experience.
                Les Parker
                • Terrys
                  • May 2007
                  • 1382
                  It strikes me as odd, that Land Rover North America would issue a tech bulletin in March of 2000 on a transmission that hadn't been imported to the US since 1995 in the Defender, 1996 (and a VERY few in 1997) in the Discovery and never in a Range Rover or Discovery Series 2. If anything it may have been a regurgitation of something generated in the UK. My 110 was dealer serviced in 2001, just prior to my getting it, and the service report indicates 8 quarts Dexron ATF. I guess Miami didn't get that memo.
                  • spacemutt
                    • Nov 2008
                    • 142
                    I've always used ATF in my LT95. EP80/90 woud be too thick when cold.
                    • cellulararrest
                      • 11
                      Redline MTL is said to be the best thing you can do for your R380.
                      • Les Parker
                        • May 2006
                        • 2020
                        Hmm,
                        Is there any data to back that? I'd be interested to see some testimonials.
                        Les Parker
                        • rwollschlager
                          • Sep 2007
                          • 583
                          Originally posted by Terrys
                          Land Rover always specified using ATF in the LT77 and R380 5 speed manual gearboxes,.
                          Is the Lt77 the transmission I have in my 72 NAS series III 88? Its a four speed, should i be putting ATF in there vs. 90wt?
                          72 SIII 88
                          67 SIIA 109
                          82 SIII Stage 1 V8
                          • Terrys
                            • May 2007
                            • 1382
                            An LT77 is a 5 speed with internal oil pump, hence the original directive for ATF.
                            You want a suitable gear oil with a viscosity in the 85 or up range, but deffinately not ATF. (Use 85W-130 for the winter)
                            • rwollschlager
                              • Sep 2007
                              • 583
                              thanks, im going to be changing all the fluids one of these weekends just makin sure im using the right stuff
                              72 SIII 88
                              67 SIIA 109
                              82 SIII Stage 1 V8
