Hey folks,
Thought I'd share some shots to a custom wrench I had fabricated to remove the crankshaft pulley from my 2.5 n/a diesel. I build a template out of an old coke carton and some duct tape and took the prototype to a machine shop where, when they finished laughing thought they'd appreciate the challenge. The tool bolts to the crankshaft pulley and the handle rests on the frame rail. Next, a 41 mm socket goes inside the tool to break loose the crankshaft bolt. Worked like a champ!!! I had to get my son to pull on the breaker bar to bust it loose, but after almost a month of trying to get the darn thing off I'm done! If anybody ever needs the tool, I can hook you up! Now I can continue with the removal of the injection pump and replacing the timing belt. With all the difficulty I had getting the crankshaft pulley off, I kinda forgot the real reason for doing this was to rebuild the injection pump and replace the timing belt!!!
Later,
Geoff
The cardboard template (Macgyver style!)
The finished tool:
Later,
Geoff
The finished tool:
