Ok folks, more on the continuing saga of the 2.5 n/a diesel injection pump removal. I've got the front timing cover removed, and as part of the process I've lined up marks on the injection pump gear, crankshaft gear, and camshaft (?) gears. According to the manual, there is also a mark on the flywheel (Remove the inspection plate and look for alignment tab), and a place to insert a timing tool that precisely aligns the flywheel (Crankshaft), and the injection pump. Picture "TimingCoverRemoved" shows the alignment of the timing gears.
The next picture "ImpossibleBolt" shows the access point for the tool that engages with the flywheel.
Unfortunately, I find removing this bolt to screw in the alignment tool impossible. I've tried universal joints, extensions, box end, open end wrenches to no avail. The only options I see are:
1) Yank the engine to gain access to the port.
2) Remove the transmission tunnel an access the port from inside.
Does anyone know how important it is to drop this alignment tool in the flywheel? Or is just getting the timing gears/marks lined up enough? I bought the two tools (One for the flywheel, the other for the injection pump iteself) that will ensure proper timing of the pump/engine, just gaining access to the flywheel is tough as it's obscured by the firewall. I've taken SO long to get this far and I'd like to wrap it up (Don't really want to put the engine), but without pulling the transmission tunnel I don't see how else to get in there. Appreciate any input.
Also, I've got a new timing belt, but did not buy a new tensioner or water pump. Should those be replaced as a matter of fact? The vehicle is "new" to me, so I don't know the history.
Thanks,
Geoff
Thanks,
Geoff
