3 point 2nd row seatbelts for 1985 110
  • evanmc
    • Jun 2010
    • 6
    Does anyone know of a kit for a 1985 110 wagon that will get me 3 point seat belts for the 2nd row?
    Thanks,
    -Evan-
  • gambrinus
    • 142
    You can walk into a NAPA and buy seatbelts all day long. Mounting brackets would be your only issue. Or just go here:
    Don't over think the simple stuff.
    • evanmc
      • Jun 2010
      • 6
      And it's indeed the mounting brackets that I don't have a solution for, nor the center seat. If there's a solution that will mount neatly into the rear pillars so I can take care of the outer seats, I'd certainly like to know about it.
      -Evan-
      • HybridIIA
        • 100
        Thanks,
        -Evan-
        I don't think there is a kit, but all of the belts and brackets are available separately. Take a look at the following link, somewhere toward the end, I have a photo of a 110 upper bracket that I mounted in my 109...
        '62 109 - coil sprung
        '64 88 - coil sprung
        • Les Parker
          • May 2006
          • 2020
          Rear forward facing mounts
          Send an email to me and I'll reply with a copy of the Def. 110 rear side set belt set up.
          Les Parker
