The infamous death wobble
  • Trini D90
    • Mar 2010
    • 1
    I have a 94 D90 at 50-55mph if I run over a bump it starts to shake, I have replaced the pan hard rod bushings and it went away for a couple days and now it is back.
    Any suggestions?
    My next thought is to replace all the bushings and damper.
  • KevinNY
    • 484
    Forget the damper, unless yours is leaking. It won't fix a wobble and it does not cause one. Your '94 is 16 years old, time to check the swivel bearing pre-load, the cause of 90% of DW issues.
    • solihull109
      • May 2007
      • 191
      X2 on the preload.
      www.downeastcoachworks.com
