Yesterday I purchased my wife a 95 D90 SW.  When I test drove it it was surging when trying to accelerate moderately or maintain a steady speed.   It almost seems as though the fuel metering is fluctuating.  It does not do it at idle or full throttle.  It will do it if you rev the engine up to 1800 or 2000 rpms while sitting still.  It drastically worsens when you turn the AC on or when you turn the head lights on.  So a strong electrical load on the system seems to affect it.  The check engine light is not on and there are no codes displayed.
So far we've cleaned the Mass Air Flow sensor. Checked for loose wire connections in the harness. Checked the alternator which is putting out 13.94v.
Any suggestions?
Any suggestions?
