You only want early 110 narrow radius arms if you are using an early 110 front axle with the corresponding narrow bracket on the axle tube. Otherwise all other axles use the wider style and thats what you want. I usually just leave the radius arms bolted to the axles when I swap them.
Disco or Range Rover axles on a 110?
A little update: I have not pickued up the 110 chassis only because the distance involved ruins a lot of the financial benefit of its cost. Right now I am considering just getting a 109 Galvanized chassis as they are ready to go and all the parts from my 109 will swap over. The exception being that I would switch to FJ60 axles.Comment
If you end up not using the 110 chassis you have located would you mind passing on the info on it? I am sure there are people here who could use it. Heck even I would consider it.Comment
