Newer Push Button 110 Middle Doors $1000
  • Jeep Rescue
    • Nov 2008
    • 21
    These are the newer style push button 110 middle doors. Welded steel frames and aluminum skins - not the galvy ones. Both doors are used, about '98 vintage, but complete and solid.
    Left Side: Very solid, no rust, I made one repair to the frame just above the lock. New bottom seal. To make perfect it will need a good sanding and minor filler. Glass is perfect. Grey door card.
    Right Side: Very solid, no rust, I made one frame repair just above the lock, and replaced the door stifener across frame at the bottom of the glass, and replaced the bottom of the door frame. Glass has some scratches. Needs a good sanding and minor filler to be perfect. New bottom seal. This one could use a new seal at the bottom of glass. Grey door card.
    Hinges do not come with, and you wouldn't want 'em anyway.
    Asking $1000 for the pair, will not separate. Shipping is on your dime. Can also arrange something through the Underground Rover Parts Railroad. Located in Washington DC.
    These doors are "rare" and hard to come by. RN has them for $2200 each, new. Even if you want to buy just the door frames, RN has those for $630 each.
    '83 110 // '58 107
  • Jeep Rescue
    • Nov 2008
    • 21
    ...and pics of the left side
    '83 110 // '58 107
