Heater core question
  • Broadstone
    • Jan 2009
    • 216
    Swapping out the heater core on my 110. Factory it was 2.5 NAD but now has defender 200TDI. The heater core I removed has the 90deg inlet and outlet pipes which face downward. Most heater cores available here in the States are straight pipes for inlet and outlet although the 90deg pipe ones are available in U.K. Is there any reason I cannot or should not use the straight pipe core? Thanks
    1973 NADA 88
  • Les Parker
    • May 2006
    • 2020
    Matrix, revisited
    You'll need to replace the heater hoses also, other than that, not a problem.
    • Broadstone
      • Jan 2009
      • 216
      Thanks Les. Yes the hoses would have to be replaced I forgot that part of it.
      1973 NADA 88
