I have having some problems with the 200tdi and wondering if you might have any ideas. It all started when I almost ran out of diesel the other week. Engine was sputtering just as I got to the station. After that it ran fine for a while like 200 miles then would start acting like it was out of diesel (mainly when it had less then 1/4 tank) Would sputter and die. I thought maybe it was just low on fuel and refilled it and it ran fine. Now it was doing it with 1/3 to 1/2 a tank today and was really bad going up hills around turns and so on. I then  replaced the fuel filter (a little bit of crude in the bottom of the bowl) but it is still having the same problems. It seems to do it more when the car has been driving for about 30 minutes or more lately. Any ideas? Is there a sediment drain on the tank? Some people are saying maybe a new lift pump or try blowing out the lines with air?
					fuel starvation
 Derek,
 Let us know how you get on, after putting the new fuel pump on.
 ATBLes Parker
 Clean the sediment screen on the bottom of the fuel pickup tube in the tank if you have one and or make sure the fuel tank is properly vented.
 It sounds like a classic case of an increasing fuel defecit due to a restricted fuel supply system whereby you can drive slowly and idle but there isn't enough fuel available for the higher demand stuff like hills and the highway. Eventually enough of a suction will develop in the fuel supply line that it will cancel out any suction from the mechanical lift pump and the engine will die.--Mark
 On The old fuel pump on the engine the lift lever thing is very week (moves very freely) well the new on in the box is very stiff. I know very little mechanically but I know one is not like the other. Also some one said to blow out the fuel lines. Any only know how hard that is?Comment
 If the fuel pump's cam follower is resting on the lobe of the cam, then hand-pumping it will likely have a different feel than if the follower is resting elsewhere, since it is already in the "fully pumped" position when the follower is on the lobe of the cam.--Mark
 Derek
 How's it driving now after blowing the fuel lines out?
  Les Parker Les Parker
 Much better, but still gives me the odd wants to stall at low speed once and a while.Comment
 I put a locking fuel cap on my truck a while ago and it ran exactly as you describe. when I went to remove the new cap it was suctioned in place on the filler neck. After popping it off the truck ran fine for about half a tank. I removed the seal in the cap and never had the problem again. 67 angry hamsters 67 angry hamsters Comment
 still having problems on start and at low speed. Its going in for the tank dropped, all the lines cleaned, and so on. Hopefully this fixes it. I have also fitted new lift pump with no change. I think there is just a lot of crud in the tank. Also I never plan on letting it get lower then. 1/4 tank again.Comment
 Still having problems. Checked the pick up screen and it's clear. Do you still think it's worth dropping the tank? Looked for air leaks and found none. The problem now the Rover will run fine half of the time. It will get up to top speed drive well but then at low speeds or a stop it will run ruff and some times will stall out when I give it gas. It also has become harder to start.
 What I have done so far.
 New lift pump and filter, blew out the fuel lines, having a oil change done today.
 I'm really running out of ideas.Comment
 Probably not going to get a lot of 200Tdi experience on this board.
 1) My only recommendations are to check the fault diagnosis chart in the 200Tdi Factory Workshop Manual for your symptoms and, failing that,
 2) Post up your issue in the appropriate spot on http://forums.lr4x4.com/ , a UK-based forum where they have GOBS of 200Tdi experience. Just know that to prevent spammers, a moderator has to approve your first 10 or so posts over there, so expect a slight delay between submitting and having the post appear on the board.--Mark
 Derek,
 Any updates?
 How is the 200 Tdi running now the temps. have dropped to freezing, or thereabouts ?Les Parker
 Seems to be a lot better after a couple tanks pf diesel conditioner, fuel lines being cleaned, replacing allmthe filters and a change.Comment
 I understand that a low concentration of biodiesel is very good at cleaning out the fuel system (plus it's the best diesel pump anti-wear additive out there, now that sulphur has disappeared from diesel fuel).--Mark
