I have a 95 auto disco. The body is off the frame, engine and trans removed, and I'm reconditioning the frame. The idea here is I am trying to do a nice off road build.
I just got a donor 95 disco with a manual trans and a nice low miles used 5-speed from roverland still in the crate. I know that the clutch box, master cyl, radiator, and all that good stuff will be changed over when I rebuild.
However, with regards to the ECU...Do I have to remove the engine ECU (the one near the heater blower) or can the one in the auto body simply be reprogramed? Is there even a trans ECU on a 95?
Also, other then the hardware involved in switching over, are there any other electrical components I should be away of?
Thanks for any help
Dave
Thanks for any help
Dave
