If I am correct, the Disco I comes with a 3.54 rear end. What other gear ratios can be fitted? I would like to fit a higher ratio - probably something around a 2.73 or so. Is that possible? If so, where can such gear sets be obtained?
Disco I rear end ratios
Why would you want to do that? I do not think it would move with that high of a ratio...3.54 is actually quite tall as it is. most Jeeps have 3.55 0r my 98 had 3.73 and the 4 cylinders all had 4.11 as well as the Rubicons...Most people look for lower gears not taller ones. I doubt taller gears even exist actually.2003 Disco SE7 expedition prepped
1998 Disco LSE 7 50th anniversary Baluga Black
1996 Disco XD Trek number 4 and Camel Selections
1969 Series 2A 109 -
Not to mention 2.73 is a lower ratio, not higher.
It is higher gearing however.
In any case, here are some alternative ratios that are available:
We are a family owned business and have been supplying quality products and excellent customer service worldwide since 1988. We are currently open and operating as normal. However we currently have longer lead times than usual; the lead time for transmissions is around 4-5 weeks. Parts orders are being dispatched as normal. We ship worldwide.Tom Rowe
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
97 D1 - ZFComment
Yeah-It doesn't help that the LT230 more or less cancels out the OD ratio of any transmission hooked to it.Comment
I am looking at doing the same thing. If I can get a 3.08 set in both axles that would put my disco II at 2108 at 70mph. Anybody know if this would be something that would hard break the drive train for make it not driveable?Comment
