Starter stays engaged.
  • orangecrush4u
    • Sep 2012
    • 6
    I had the starter swapped and rebuilt and it stays engaged but when I turn it off it stops. I'm thinking it's in the key switch and not the starter. I think I might put in a push button and eliminate the key crank. Any Thoughts???
    46 cj2a
    69 bronco
    72 bronco
    74 bronco
    76 wagoner
    79 bronco
    95 disco
    03 focus svt
  • Les Parker
    • May 2006
    • 2020
    Sounds like a bad ignition switch, probably a worn electrical part. Is it manual or auto?
    # RNH583 Switch and harness. In stock.
    Les Parker
    • orangecrush4u
      • Sep 2012
      • 6
      its a 5 speed, so it sounds like the ignitions switch eh? are they difficult to swap out?
      46 cj2a
      69 bronco
      72 bronco
      74 bronco
      76 wagoner
      79 bronco
      95 disco
      03 focus svt
      • mearstrae
        • Oct 2011
        • 592
        Not too difficult to change out, pretty pricey part though. Hardest part is removing the clamping bolts, I had to use a sharp punch to coax mine out, after that just unplug the old, plug in the new, and rebolt it in place with new bolts. (They use pretty strange bolts for this, I don't know why...) Look for a 'RAVE' disc with the shop manuals on it, if you don't have a manual, it's a free download on the net.
        '95 R.R.C. Lwb
        '76 Series III Hybrid 109
        '70 Rover 3500S
        • orangecrush4u
          • Sep 2012
          • 6
          '95 R.R.C. Lwb
          '70 Rover 3500S
          Do ya think I should just put a starter push button in and be done with it??
          46 cj2a
          69 bronco
          72 bronco
          74 bronco
          76 wagoner
          79 bronco
          95 disco
          03 focus svt
          • mearstrae
            • Oct 2011
            • 592
            May be a cheaper way to go. I don't know if the small switch at the end of the complete ignition set-up is available by itself, it's probably all you'd need. On mine the key got jambed and I had to change the works, same symtoms; engage starter and it keeps cranking, the key mechanism wouldn't let the switch return to normal run.
            All you'll need to do if you put on an external start button is deactivate the start wire at the steering column switch and run fresh wires.
            '95 R.R.C. Lwb
            '70 Rover 3500S
            • orangecrush4u
              • Sep 2012
              • 6
              '95 R.R.C. Lwb
              '70 Rover 3500S
              ok thanks, going to order up a starter switch this week.
              46 cj2a
              69 bronco
              72 bronco
              74 bronco
              76 wagoner
              79 bronco
              95 disco
              03 focus svt
