My 1995 discovery will starts some times witout any problems about every 3rd time and then it will take a long time to crank after pushing the gas pedal serveral times. I have tested the battery and changed the alternator and they are good. Stater is good. When it has the problem you can smell gas when it is trying to start. Once cranked it seems to run ok. i have taken it to a local mechanic and he was unable to find the probelm. Tested the computer and can't get any infromation from the computer. Gets spark and fuel. Fuel pressure about 34 but goes down right after the LR is turned off. Was told should hold pressure for 20 minutes.
Would appreciate any help?
Thanks and God Bless,
Chris Archer
Chris Archer
