I need advice/assistance for installing larger break calipers & rotors on my 1996 Discovery1. I've been advised that the most popular upgrade is break calipers & rotors off of a 1995 Range Rover Classic. I have the calipers & rotors but can NOT locate the mounting bracket required. The mounting bolt holes are different spacing from the original Discovery breaks. Does ANYONE know where I can find this break swap kit.........or just the mounting bracket?
Issue solved.......the bigger brakes that fit directly to the D1 is the 1995 Defender rotors & calipers. Great brake upgrade for D1's.
