98 d1 will not crank, after running a couple of errands yesterday, i tried starting to no avail. Sometimes when the key is turned to pos II the dash lights will either be normal, and turning to pos III results in a click as if dead battery or bad starter. Then releasing the key to pos II there will be a clicking like a faulty relay under right hand fascia. Other times turning key to pos II will result in dim lights and turning to pos III will result in clicking noise. Battery is good ,and starter was not acting up. Any usual suspects to check first ?
Ed
Ed
