Disco I front end wobble
  • cmp517
    • May 2008
    • 2
    The wobble only occurs after I return the steering back. As I'm making a turn,most often to the right, it almost feels as if I have a flat, but when I return it to go straight it seems as if the front axel is walking almost like what you would feel from a real tight turn while in 4 wheel drive
  • KSMTAW
    • 93
    Have you figured out what the problem is?
    Todd
    Todd
    66 IIA 88"
    93 Porsche 968 variocam 6spd
    50 Ford 8N
    • pfhooper
      • Jun 2008
      • 4
      Wobble
      How old is your steering dampner? If all the other critical front suspension parts are OK - then might be it...I had similar symptom cured by OME yellow dampner - Hoop.
      • Paul Grant
        • 57
        A steering damper doesn't cure a problem. It merely hides the symptoms. A properly set up vehicle shouldn't need a steering damper to to conceal vibrations. I think it's time to get the front end in the air so you can do a detailed inspection.
        paulgrant@mac.com
        203-770-1699
        • SGFMORover
          • Mar 2007
          • 91
          almost sounds more drivetrain than suspension/steering. cv joints/axle shafts?
