Transfer gearbox gasket leaking
  • JohnMc64
    • Oct 2008
    • 9
    Whats the best way to seal the plate on the TG?
    I've tried liquid gasket but it leaked. Removed the liquid gasket and then tried a rubber gasket but that leaks too.
    Should I use a cork gasket?
    I've made sure both surfaces are clean. Does not seem to have an pitting or scratches around the plate surface. My best guess is that the leaks are coming from the bolt thread holes. Should I use locktite on them?
    JohnMc
    QC Canada
  • Les Parker
    • May 2006
    • 2020
    Have you checked for warpage?
    I would try the thread sealer and ritestuff either side of the paper gasket.
    Les Parker
    • JohnMc64
      • Oct 2008
      • 9
      leaked fixed
      Thanks Les.
      I did verify that the plate was not warped. Can't say enough about hand tightening those bolts in a 'balanced' fashion to prevent warpage. Small steps and less mistakes.
      I tried your suggestion of locktite on the threads and it worked! No more leakage. I was told to check the bolts a few days later to make sure they are snug BUT I think I'll leave them alone. I don't want to break the seal that seems to be working.
      Thanks again.
      JohnMc
      QC Canada
      • Thaniel
        • 16
        Are you positive the leak is from the plate. Mine appeared to be seeping from there but when I had it out of the truck it was actually leaking at the seal between the transfer case and transmission and running down then wetting the plate.
        Just a thought.
        • Hammer38
          • Oct 2007
          • 62
          If you got the means to get the t-box out of the vehicle, I'd replace all the seals & reseal the gear housings w/Right Stuff.
