Does anyone know where the "lights still on indicator" is located (when you cut the engine and leave the lights on it beeps..well used to). I think mine is going out or coroded and it is causing fuses to blow, included in this fuse block is the right side lights. I checked all of the grounds and cleaned them all...fuses still blowing. I could not find it on the RAVE cd anywhere. Any help would be appreciated on this issue.
Thanks .
Thanks .
