This is my first ROVER, a 98 Disco I. I'd like to start setting it up for some WHEELIN!!! Can anyone tell me what size tire I can fit under a Disco I with a 2" lift... BIG THANKS to anyone how can help!!
Tire Size!!!
Originally posted by Joey4420Depends on if you want to trim your fenders... 245-75-16 will fit with minor triming.
Hey Joey, Thanks for your insight on my problem. I don't mind alittle trimming... I would like to go 235/85/16 I think that's about 32" tall. Do you know if a 1" body lift would help fit the larger tires or would that just be lame...
Les Parker
I have BFG AT/KO 245 75 16 on my stock DI's.
Back - was fine...not cutting...plenty of clearence
Front - I had to trim a bit of the plastic front bumper ends (which I ended up just cutting off flush with the bottom of the front bumper anyway
No lift....stock springs....looks great I think! Don't have any of those camber/caster or u-joint problems you get when you lift"Out of every one hundred men, ten should not even be there, eighty are just targets, nine are the real fighters, and we are lucky to have them for they make the battle. Ah, but the one, one is a warrior, and he will bring the others back"Comment
