If I could bother anyone with some help. I have a 1996 Discovery 5 speed with 209000 miles. The truck just stopped. I have no fuel pressure at the rail. I checked the fuse, relay, roll over switch and are all good. I have power to the pump and a good ground. I pulled the pump and tried to see if it would run if I hooked it directly to a battery. The pump ran ok that way. After putting the pump back in, I checked the volts to the pump and all was well. Just wouldn't run. So I tried to see if the pump would run directly hooked to a battery while installed. (I tried this same method earlier) This time no go. I wondering if I need a new pump or is it something else I missed. Don't want to just throw money at it with out hooking up test bookin this economic climate.
Adam
Adam
