Hey gang.
New guy here (not new to Land Rover, have had mine for 5 years)
Here is the issue. When cold the engine starts fine. As it comes to operating temperature, say after I have gone to the store and then come back to start it up after about 10 minutes or so, it sputters revs are very low and it stalls. I try again and it does the same thing. If I am luck and the revs stay at say 200rpm and I hit the gas pedal and keep it at about 2000rpm it is ok enough to get going and then it drives fine.
After it cools down for about 20 minutes it starts ok again.
It is a 1997 Discovery. non advanced emissions family. 170K km on the clock.
I have changed the following within the last three months:
New NGK ignition wires.
New Champion plugs
New Coolant Temperature sensor
New O2 sensors post catalytic convertor
Relitively new O2 sensors pre cat.
New gas cap
New Thermostat and gasket
New Coolant
New Battery
New Oil
New Air Filter.
Cleaned the MAF
Cleaned the Stepper motor
Cleaned the Throttle position sensor
I don't know where else to look. I have on order the following parts:
Fuel temperature sensor (for in the fuel rail)
New Fuel Filter
New hoses for the PCV system
The little oil separator that goes in the left hand valve cover.
Apart from that I am lost. It starts relitively fine. There is spark and Fuel. The only codes it ever threw were for the O2 sensors.
I have read that the fuel temperature sensor can cause hot start issues.
Any help would be greatly appreciated.
Thanks all.
New Champion plugs
New gas cap
New Coolant
New Battery
New Oil
New Air Filter.
Cleaned the MAF
New Fuel Filter
Thanks all.
