Check engine light
  • jimbonz60
    • May 2009
    • 1
    Check engine light
    Hi folks you have all seen this question before,
    I have trawled the forums trying to find a solution, No joy. So I will be as concise as possible. ECL comes on shortly after statup, it stays on until I give it a rev, or when driving, I back off the throttle, it stays off for about the same amount of time as it took to come on at startup then comes on again.about 10 seconds
    Short history: head casket was blown due to lack of water has been replaced head was planed and checked new seals etc. Also replaced cam belt while it was off the road. its done 198Ks and is a TDI 300 1995 Discovery. There is no display under any of the seats and I have looked in the area where the fuses are and had the glovebox out. I admit to being a bit blind but I cant find anything with a display on it. Am I missing something
    Cheers and thanks in advance
