I Belive that I have two problems or more. When the rover is cold the engine is runs quietly but after it warms up there is a tapping noise. The engine is not overheating so the temp guage says. I only take the rover on short trips about 5 miles to work with no problem, but I went into town and I herd the tapping. The temp guage was still normal temp, I turned on the heater on high seemed normal temp,
When the engine idles in drive my oil light comes on I put it into netural and the light goes away.
I also just got a 48 code, witch is the stepper motor and Idel control. I tried to clear it but it came back.
Any info would help, should I get a real temp and oil pressure guage what brand would you recomend, should I change my oil pump, stepper motor
anyway thanks for the help last time, Rockon
