Opinions? rear sway bar with OME suspension
  • Cosmic88
    • Feb 2009
    • 78
    Everyone has one so here is your chance to share
    on my '95 disco I have Old Man Emu heavy duty shocks and 2" lift heavy springs. With that setup do you think I should lose the rear sway bar? On / Off road use is about 60% / 40% respectively...
    -Cosmo-
    '95 Disco R380 5 spd DD
    ARB winch bull bar
    Warn 8k
    Gulf States Grill
    OME HD 2" lift
    home made limb risers
    LR rack with too many Hellas
    on-and-on-and....
  • spacemutt
    • Nov 2008
    • 142
    Lose it. It will only restrict the travel of your suspension. It will probably be stiff enough with the heavy duty set-up anyway.
    • joshua.mcguoirk
      • Sep 2007
      • 122
      Removed front and rear
      I have the same setup on a '96 D1. I have removed both the front and the rear with no issues. Initially took a little time to get used to the roll of the vehicle going around turns... but that is all in the past.
      1990 RRC, 3.9L, AUTO "Willow Pond" (Sold)
      1996 D1, 4.0L, AUTO "Lucas"
      1999 RR, 4.0L, AUTO "Belle" (Sold)
