95 disco wont start. have fuel to the fuel rail. just changed the ignition coil. it has a positive and negative trminals on it. dont know if its polarity sensative. checked spark on the main wire going to the dist. cap. dont know what to check next. any advice would help. thanks.
no spark, help!
Take the coil wire of the dizzy cap and ground it, while turning it over, do you have spark?
Check your connection at the coil .
Did it run before you changed the coil? -
new to this. im guessing dizzy cap is distributor cap. yes i took the center wire going to the cap and tried to ground it while turning over, no spark. im getting about 7 volts dc to the coil with the key in aux. 2. not sure what it should be. i took the wires off the coil and checked them for voltage and put the positive on the pos. terminal. only two of the four have voltage. im guessing the other two are recieving voltage.Comment
Lastly... I recall the coil needing 12V.1990 RRC, 3.9L, AUTO "Willow Pond" (Sold)
1996 D1, 4.0L, AUTO "Lucas"
1999 RR, 4.0L, AUTO "Belle" (Sold)Comment
Did you get any spark from grounding the coil wire? If no spark, you either have a bad coil or a bad ignition module..Comment
