Idle High, Idle Low
  • jonnyrover
    • May 2007
    • 20
    Idle High, Idle Low
    My 96 disco started a new game with me last friday... it decided to start idling down from around 700-900 rpm (normal) to nothing and then die multiple times. It always restarted but i had to throw it into neutral and keep giving it gas (whenever i came to a stop) until i got to where i was going. Then i let it sit while my little boy and i were at the doctor 45mins. +/-. When i got back in there was not a problem to be seen. That is until this morning (wednesday) when the engine began idling at around 1300-1400 rpms. Then it started to idle low again 10 mins later. By the time i got to work it was fine again.
    My guess is bad gas or clogged fuel filter... Any insight? I will probably be buying some injector cleaner this afternoon to begin the troubleshooting process. Thanks.
  • jonnyrover
    • May 2007
    • 20
    never heard back from any one on the issue. but i added EFI cleaner and have since replaced the fuel filter. no funky stalling so far... hopefully, i found the problem and fixed it!
    • SGFMORover
      • Mar 2007
      • 91
      fuel issues are likely; if it hapens again see if it'll maintain idle in park or neutral vs drive. voltage problems would be the next route after that.
