1996 disco i
  • bluerover95
    • Sep 2010
    • 13
    1996 disco i
    tach not working, speedometer sometimes sporadic, temperature gauge fluctuates, brake lamp blinks, low fuel lamp on and off....... this disco has new alternator, water pump, radiator, viscous fan, temperature senders ... can it be the green 5 pin relay that looks at several things?
  • achampagne
    • May 2010
    • 31
    Make sure you routed the belt correctly, and check the tach connection on the alt.
    • SGFMORover
      • Mar 2007
      • 91
      only thing that comes to mind that those share is maybe the ground connection in the footwell?
      • singingcamel
        • 398
        Bad alternator
        www.singingcamel.com
