Need some of the members expert advice please !!
1997 Discovery........fixed cruise back last fall by replacing all vacumn lines.....worked like a charm afterward. Now all of a sudden it has started acting up. Sometimes when I hit the set button it will engage ......sometimes it won't. I cut off using dash switch....give it a little time and then cut it back on via dash switch......hit set button....it will engage for a few seconds and then disengage. Just very erratic..
The only other thing I have noticed is that about the same time as the cruise started acting up the rear windows did too. Sometimes they work...sometimes they don't ! They too were working perfectly prior to this.
HELP !
Thanks,
Doug
HELP !
Thanks,
Doug
