Headliner Replacement
  • msmith1
    • Feb 2012
    • 8
    I have a 04 Disco in need of a new headliner. Would like to do myself. Anyone with experience as to how easy this project is? Thoughts and or suggestions?
    Matt
    Matt
    04 Discovery II
    04 Volvo XC70
  • knac1234
    • Nov 2010
    • 442
    Sorry, no thoughts, but would like to replace mine as well. So, will keep an eye on this thread!
    Julian
    Julian
    72 Series III NAS
    03 Disco
    65 MGB / 73 MGBGT
    71 RHD Hillman Super Imp
    • BackInA88
      • 332
      I pulled mine down and removed all the fabric and foam.
      Wire brushed and than used a wet scotchbite pad to remove as much of the glue as possible. Than rinsed it down and let dry in the sun.
      Went to the local hardware and bought some Krylon plastic paint that matched as close as possible.
      Sprayed the whole head liner with 2 cans, which just covered it.
      Looks like a swede leather to me and I am happy and it will never need to be redone.
      Steve
      71 IIa 88
      01 D2
      • bkreutz
        • Apr 2010
        • 408
        Matt
        Not real difficult, just time consuming. You need to remove all the A,B,C, and D pillar trim, along with all the stuff screwed into the roof. It's easy to come out if you're not worried about saving the old one, putting the new one is easier with 2 people. I used to have to do this a lot because every time the sunroofs have to be replaced (quite often) the headliner has to come down. After a while I figured out a trick where I could remove the sunroof by just dropping the headliner a couple of inches and work through the gap. Take your time and don't force anything and you'll be fine.
        Gale Breitkreutz
        '03 Disco
        '47 CJ2A
        • 1996trek4
          • Mar 2012
          • 52
          They make foam lined headliner material that is a very close match. I've done it on a few RRCs... Have yet to have a failure on any of my Discoveries...I've never had to replace a sunroof either-ever...Keep your drains clean and you should never have a problem with water leaks destroying your headliner
          2003 Disco SE7 expedition prepped
          1998 Disco LSE 7 50th anniversary Baluga Black
          1996 Disco XD Trek number 4 and Camel Selections
          1969 Series 2A 109
