Disco ll want start
  • benson118
    • Apr 2013
    • 9
    Disco ll want start
    Just bought my first Rover 04 se 51K. Drove it for a week before I bought it no problems and then the M&S lights started flashing which could be corrected by shutting off and turning back on no real pattern on this it's hit or miss. Also I stopped the other day turned it off all the way off key still ignition sat for 30 min when I went to start all lights came on as they should but nothing with key to start position will not start.
  • RNZack
    Administrator
    • Sep 2011
    • 426
    Could be a few different things, but certainly hints at a CPS(crank position sensor) failure. Where are you located?
    • benson118
      • Apr 2013
      • 9
      Atlanta Ga.
      • benson118
        • Apr 2013
        • 9
        Ended up being the XYZ switch on the side of the trans. Only a $700 part and $300 to install. Sweet! Lol
        • Les Parker
          • May 2006
          • 2020
          Thanks for the follow up posting ! Another item to add to the list of possibilities in "no start" situations.
