ive been leaking antifreeze in my 99 LRII. i checked the fluids  and they were low and there is a little dripping when im parked.i checked all the hoses around the block but nothing. its on the drivers side where the only place it could be coming from would be the water pump seal.i cant really see underneath where its coming from, but it looks like its dripping down onto the oil cooler lines and travels down. anyone that can help or whos had this problem let me know...thanks
					antifreeze leak....
 It might be the front cover gasket. Remove the top part of the fan shroud (easy), take a Maglite and look where the timing cover mates to the engine block ,straight down from the left cylinder head and you may see a tricle there. While you're in there look for a stain or a leak at the bottom of the rad on the passenger side.Also check the throttle heater under the throttle body on the left hand side of the engine.It's not very big but the gasket fails and it can leak quite a bit.
