Drive shaft woes
  • jackson01disc
    • Dec 2007
    • 6
    Drive shaft woes
    My front drive shaft has went out at the front joint. I have already ordered a new one and Rovers North said this was a common problem for discos. My question is though when I took out my front drive train should I not be able to still drive with rear wheel power. Mine would not, also would it be possible to just replace the joint and not the whole $400 dollar part?? Any answers would be GREATLY appreciated!!
  • BackInA88
    • 332
    Do you have the CDL nipple?
    Check out this posting it will tell you where to look for the CDL nipple.
    LR still had the CDL nipple on early production 01's, I got lucky and have it!
    If you do you can reach up and turn the nipple with a 10mm wrench clockwise when looking from the top or counter-clockwise looking from below.
    Your ABS and TC lights may come on.
    You can than drive it as rear wheel drive only until you replace the front drive shaft.
    When yours broke did it do any other damage when it was flying around?
    They are known for cracking the transmission case.
    Here is a big write up on using a Dodge Durango front driveshaft.
    Bolts right in, has bigger u-joints and is cheaper.
    Steve
    71 IIa 88
    01 D2
    • jackson01disc
      • Dec 2007
      • 6
      Nope there was no damage done since it actually did not come apart. It broke just on one side of the connector. It started shuttering heavy so I was able to get it to a mechanic. I got away alot better than what could have happened. A durango front drive shaft would really fit?? No problems?? And Thanks for the reply
      • BackInA88
        • 332
        Problems??
        I only know what I have read on the dweb.
        I know I will be looking into this when I replace mine.
        71 IIa 88
        01 D2
        • DiscoDave
          • Nov 2007
          • 12
          Jackson if only the u-joint went bad it's an easy remedy, and done at home. U-joints can be had locally so no need to special order. If I were you though I'd do all three at the same time so you know what you're dealing with, and make sure they are all serviceable so you can maintain them (unlike the ones that came stock.)
          While the Dodge Durango phenomenon has been floating around all of the of forums, nobody I've talked to and nothing I've read has anything specific on what year, make, model, engine, etc that would work. For now I'll be happy rebuilding my own.
          PM me if you need some u-joint cross reference numbers.
          1973 Series III
          1995 RRC LWB
          2000 Discovery II
          2000 Range Rover
          • JimKellyfan
            • Jul 2008
            • 11
            what r the p/n's ?
            And will they work in a 99 DII?
            Are they serviceable as well ?
            " I am not a robot. I don't like having discs crammed into me unless they're Oreos. And then only in the mouth." - Frye
            • kh500
              • Sep 2007
              • 37
              i did mine last year.
              Disco II, 2000, 90K mi, Northern NJ - http://www.mysaab900.com/gallery/Discovery_2000/
