I want to tow my Disco behind my RV. Can that be done with a car hauler that mounts the front two wheels?
Pulling 01 D2?
Tags: None
You can actually tow it with all four wheels on the ground.
With engine running and transmission in neutral;
Shift the transfer case into neutral (between Low range and High range).
Then put the transmission into park and shut off the engine.
Release parking brake and you're ready to go.'04 Land Rover Discovery S
Way over 100 Off-Road TreksComment
