I have an 03 disco w/ the 4.3 and the GEMS. When it idles after it gets completely warmed up, I am getting a blinking oil pressure light. I tried changing the pressure switch. I flushed the engine and changed the oil twice. I am running 10w-40, non-synthetic. Still getting the blinking light. If I raise the idle slightly, the light stays out. It only has 60K on the engine, and the oil was changed at least every 5K, normally at every 3K. I can't imagine it needs a new oil pump. I do not have a pressure tester. Could it be something simple like the PCV system? Please let it be that, I can't spend the approximate $2,000 to change the oil pump.... Please get me some good advice.... Thanks.
Oil pressure problem?
X2 drop the oil pan and check the pick up. then replace the oil pump.
Kevin
04 XJ8
92 RRC
02 Benz E320
95 RRC (sold 5/10)
72 Series 3 (sold 4/10)
70 Series 2A (sold 6/10)
Morgan +8 (sold 8/09)
90 Jetta (308k miles) (sold 5/11)
72 Triumph Stag (sold 1/08Comment
Kevin
04 XJ8
92 RRC
02 Benz E320
95 RRC (sold 5/10)
I just went through this with my 3.5 litre V8. Oil Pump gears and a new oil filter housing (half of the oil pump housing) fixed me right up for less than $100 and a bunch of shop wrags. Your engine has a different oil pump configuration than mine - so your resuklts may vary.Firemanshort
1980 Stage One
