Blend Door or Blend Motor or Servo?
  • Ilya
    • Nov 2007
    • 32
    On my Discovery II 2000 heater or ac to blow hot or cold air even when AC or Heater is off. From what I understand it is blend door,motor or servo that is responsible.
    So what is the right name for the part? or parts?
    Where I can get it?
    Thank you
  • Colorado Rover
    • Jul 2008
    • 29
    Ilya- I had same problem and it repeated itself 30 days later. If what you describe is the same you need the belder motor. I believe it is the motor and door are one unit. THis is a fun job too.
