Axles on D2
  • roven
    • Jan 2010
    • 35
    Axles on D2
    Been looking into lockers for my 2001 D2. Does anyone know what the axles are or called ie. Dana 44 etc.? I'm interseted in Eaton's E-Lockers.
  • 98 HOO
    • Feb 2010
    • 23
    I believe D2 axles are rover specific - not a Dana assembly. I have not heard that Eaton E-lockers are made to fit the D2 axles. Lucky8llc.com was working on a KAM e-locker I believe, but it doesn't appear to be on his site any more. You might want to give Justin a ring and see if he has them. Might only have the Detroit, TruTrac and ARB air lockers to choose from.....
    '82 109" diesel
    '04 DII
    • roven
      • Jan 2010
      • 35
      D2 axles
      Thanks 98HOO. I know I can get ARB lockers but didn't want the hassle of air leaks. This seems to be a commen problem unless you change every seal from end to end a little to often than I'd like. They also recamend diff oil changes twice as much! thanks for the reply though.
      Roven don't use R
      • stu454
        • 53
        Eaton Detroit and Truetrac are available for the D2.
        Stu
        '01 D2
        • msggunny
          • 621
          If you want E-lockers i believe there is a mod for the toyota e-locker out there for the d2's now.
          There is diffidently one for the d1's and rest of the rover axles, i remember seeing something for the d2's too.
          Check out dweb.
          04 DII
          08 D3 (LR3)
