Looked through old post but didn't find out if I could take a 2003-4 transfer case and put it in my 2001 D2 so I'd have CDL. Anyone know?
Transfer case
Yes, you can. You need the case and shifter assembly (they are different). -
First, do you have the CDL nipple on top of your existing t-case? If so, then you only need the shifter linkage with which to activate the diff lock and Hi-Lo.
Second, the '03 D2 did NOT have CDL, so that's a non-starter.
Now, if you don't have the CDL nipple then you'll need the front portion of the '04 t-case. A '99 to early '01 t-case will work as well.Stu
'01 D2Comment
